soldering easy-fit copper connections
dougthetruck
by dougthetruck » Tue Jul 31, 2007 5:37 am
I have moved underfloor copper shower pipes using easy-fit connections, my question is: is it adviseable/possible to solder the joints or is the gap between the original pipe and connector too big? My reason is: i dont want to lay a new tiled floor and then have a problem later with leaky easy-fit connections resulting in ripping up the floor. A 'friend' says i can trust the east-fit!!
johnb
by johnb » Tue Jul 31, 2007 5:29 pm
hi doug , do you mean push fit if so and you follow simple instructions they are great don't be afraid all the best john
It is currently Mon Dec 23, 2024 8:30 pm
