Cloaking fillet - what do I stick it with?
mosis
by mosis » Sun Jun 23, 2013 6:15 pm
Hi, I removed the old cloaking fillet from around my bedroom window, and have bought new ones and cut them to size. There is a 1cm gap between the window frame and the wall, as shown in the photos below. Before I removed the old cloaking fillets (the bottom one of which had gone black in places due to mould, and looked horrible), there was no draft, and no sound from outside, but now that there are no cloaking fillets, I can hear traffic much more easily, and there is some air getting in through the gaps. (Nothing terrible, but it will be pretty bad in the winter, I imagine).
Should I fill in the gap with filler before putting the new cloaking fillets on, and what should I use to stick the cloaking fillets on? Do I use silicon sealant, or some 'No nails', or something else? I read on another forum that somebody had had difficulty getting the top fillet to stay in place while the sealant they used dried, so I wanted to make sure I did it properly in the first place.
Many thanks in advance for any help you can give.
Re: Cloaking fillet - what do I stick it with?
by welsh brickie » Mon Jun 24, 2013 11:41 am
you can buy double sided sticky tape or trim tape as its known, stick it to the plastic trim first, then against the window. Then silicone the gap between the window and the trim, then use acrylic sealant on the gap inbetween the trim and the plaster
It is currently Mon Dec 23, 2024 9:36 am
