Estimating above ground MDPE blue pipe insulation for UV damage protection
gibby69
by gibby69 » Mon Jul 01, 2013 10:01 pm
I've been asked to estimate the insulation of above ground mdpe (blue) pipe. It's to protect against UV damage, and has to follow the byelaws (Scotland). Information I requested from scottish water was just basic leaflets. Any ideas what type/thickness of insulation I should be looking for.
Thanks.
Re: Estimating above ground MDPE blue pipe insulation for UV damage protection
by htg engineer » Fri Jul 05, 2013 5:12 pm
Black Polyethylene pipes should be used for above ground potable water supplies, so it doesn't meet regulations to start with.
Have a look at:
http://www.southernwater.co.uk/pdf/prop ... lyRegs.pdf
unfortunately not Scotland but should be a good start.
It is currently Fri Nov 22, 2024 11:12 am
