UPVC back door and Kitchen window fitting
6 posts   •   Page 1 of 1
texteditor
by texteditor » Tue Jul 09, 2013 4:25 pm
Have just taken delivery of the above, do I install them complete with door and opening light in position?
or remove them and refit later?
Thanks, texteditor.
Re: UPVC back door and Kitchen window fitting
by welsh brickie » Tue Jul 09, 2013 6:52 pm
fit the door first, you should have a joint strip, clamp it to the door with the window then fix it to the door frame and screw together
texteditor
by texteditor » Tue Jul 09, 2013 8:04 pm
Sorry, they are totally separate, Question- Do I install the frames with the opening light and the door attached or do I remove the door and opening light and then fit the frames and then put the door and opening light back in the frames and fit the glass?
Thanks, texteditor.
by welsh brickie » Thu Jul 11, 2013 12:28 pm
no with the door attached and the sash in place, Fix the door hinge side first plumb and level, DO NOT fix the lock side until the window frame is fixed to the door, then eye up the frame as you close the door then fix it or it will be out of alignment
texteditor
by texteditor » Thu Jul 11, 2013 1:05 pm
I have a Door
I also have a window
They are going in totally separate openings- there is about 500mm between them.
I fit them with door and opening light in place (thanks for that)
Can you outline the rest of the process please.
Thanks, texteditor.
by welsh brickie » Fri Jul 12, 2013 9:58 am
with the door, fix in place hinge side first, make sure there is no bow in the frame, pack and fix the door cill level, then slowly close the door and eye the frame to align with the door, check the lock position and it closes perfectly, then drill and fix in position
the window is easier just make sure the frame is not twisted or out of level
It is currently Sat Nov 23, 2024 1:46 pm
