by GeckoGas »
Thu Aug 02, 2007 9:00 pm
Unfortunately you cannot simply run at half gas, the gas pipework in your property will need to be sized (where possible) to find out exactly what rate of gas it can provide... And that it can meet the maximum demand for the appliance.
Some common solutions I have employed that can be run on 15mm are:
- Worcester Bosch Junior's 24i (Combis)
- Classic SE (System)
- Keston C25 (System)
You need to ideally work out your heat requirements and go from there; but all the above are suitable with some careful planning and calculations.
