Block up external doorway
6 posts   •   Page 1 of 1
johnyoung
by johnyoung » Mon Aug 05, 2013 4:58 pm
I have an external doorway in a pebble-dashed 9 inch brick wall which I would like to fill in. Would I have to comply with current insulation regulations for this short piece of wall or can I just fill in with 9 inch blocks and plaster and render afterwards??
Thanks. . .
Re: Block up external doorway
by welsh brickie » Mon Aug 05, 2013 6:35 pm
yes, its best to insulate it anyway its for your benefit
johnyoung
by johnyoung » Mon Aug 05, 2013 6:56 pm
Thanks for your interest - so are you suggesting say 3 inch blocks 2 inch cavity and 4 inch studwork with something like Jablite between??
johnyoung
by johnyoung » Wed Aug 07, 2013 9:45 am
Seems the thinnest drytherm is 50mm - meaning there would be no cavity with 75 and 100mm blocks - as the total width would roughly add up to the thickness of the wall.
I suggested stud on the inner skin as it would probably be quicker to put up and the insulation could be put between the studs and there would be a cavity between. . .
by welsh brickie » Wed Aug 07, 2013 3:57 pm
sorry I must have been half asleep writing this, I didn't read your problem properly, it would best to build your doorway in thermalite but lay them flat. As your existing walls are 9 inches thick with no cavity then its pointless creating a cavity for the doorway
johnyoung
by johnyoung » Thu Aug 08, 2013 5:03 pm
That sounds completely logical - Thanks for your help. . .
It is currently Mon Nov 25, 2024 2:30 am
