What type of insulation should i be using?
Millsy
by Millsy » Tue Aug 06, 2013 10:35 pm
Hi guys I'm wanting to insulate my little girls bedroom as it gets freezing in winter, we live in a dormer bungalow and I've found she has no insulation in the 2 stud partition walls which form her bedroom, the outside wall has cavity wall insulation, the flat section of her ceiling has loads of loft insulation on top, but the 45 degree sections of her ceiling also have no insulation!
I would like advice on how to insulate the 45 degrees sections mainly? The rafters are 3" deep, there is roof lining and then tiles. Any suggestions for the partition walls would be good too, they are plaster board on 3" joists backing into a small loft section, again this has loads of insulation on the floor but nothing up in the rafters.
Thanks in advance for any help given.
Millsy
Re: What type of insulation should i be using?
by Millsy » Wed Aug 07, 2013 10:29 am
Hi all
I've added a couple of pictures which will hopefully help
Brett
Roof lining
Roof lining
Rafters and lining
Rafters and lining
Millsy
by Millsy » Wed Aug 07, 2013 5:44 pm
How do you know if roof lining is breathable? ie being able to push fibreglass styles insulation directly onto the lining?
Thanks again Brett
by welsh brickie » Wed Aug 07, 2013 10:48 pm
you need rigid insulation boards like kingspan 50mm thick leaving a 25mm airflow, easy to install and cuts with an ordinary saw just jam it in place
It is currently Mon Dec 23, 2024 6:24 am
