Pipes in Wrong Place for New Towel Rail
Wetfool
by Wetfool » Mon Aug 12, 2013 7:27 pm
Hi, i took out an old towel rail and the pipes were only 150mm apart. I now want to add another towel rail and don't want to drain the system down. Can i fit a bit of pipe from the valve to the towel rail from each end to bridge the 200mm gap each side. What fittings do i need to do this?
Cheers, N.
It is currently Thu Jan 09, 2025 11:53 pm
