Replacement Cooker Hood and Diameter of Ducting
jgoldman
by jgoldman » Tue Aug 13, 2013 11:35 am
My cooker hood needs replacing and the current ducting has a diameter of about 110 mm (external measurement). However, the usual ducting diameter for cooker hoods seems to be 100, 125 and 150 mm. Am I correct to to take an external measurement and Is it possible to find a reducer or adapter to allow fitting?
Many thanks,
Jeremy
collectors
Re: Replacement Cooker Hood and Diameter of Ducting
by collectors » Wed Aug 14, 2013 4:52 pm
It sounds like you have either external flexible underground duct or dust extraction hose as this size is a common 110-114mm. Sounds like the builder had some spare.
Remember that Cooker hood duct should be of a fire resistant material for obvious reasons.
jgoldman
by jgoldman » Wed Aug 14, 2013 10:55 pm
Thanks for your comments. The pipe is not flexible. It's solid plastic. How would I know if it's a dust extraction hose? Would this also be flexible?
Many thanks,
Jeremy
