Colour of Pointing Mortar of Gable End Mortar Joints
Frenchman69
by Frenchman69 » Wed Aug 21, 2013 7:44 am
Hi Guys
My gable end bricks are lacking mortar in some areas, I think due to prevailing winds, and living 1/2 mile from the sea.
Being 72 but reasonably fit, I try to do what I can to save money, so decided to re-point to do so.
Trouble I am having, is matching up the mortar colour, I start using 3 in 1 using red building sand, but some has dried VERY grey, so now I have gone to 4 in 1 which is better.
Are their any guide lines or has one got to use his eyes simply, our present mortar seems to have a slightly pink colour or maybe beige.
The bricks re unlike common, they have fancy squiggly lines, so I find it hard to wife off mortar if it goes on them, so they dry horrible, especially if its grey.
Re: Colour of Pointing Mortar of Gable End Mortar Joints
by welsh brickie » Wed Aug 21, 2013 3:47 pm
try lime in the mix cement lime sand 1.1.4. to clean mortar off the bricks use brick acid
Frenchman69
by Frenchman69 » Wed Aug 21, 2013 5:35 pm
Welsh brickie
So does the lime sort of take over what the 3in 1 or 4 in 1 colour would be ?
I certainly will buy some, also brick acid as I have heard both mentioned a lot on forum.
Normal safety precautions I assume with the brick acid?
by welsh brickie » Wed Aug 21, 2013 8:52 pm
lime alters the color and acid breaks down the cement when its set
Frenchman69
by Frenchman69 » Wed Aug 28, 2013 6:40 pm
The lime certainly altered the colour, it came out almost white, yet I did a 1x1x4.
And the brick acid was a disappointment, and I think the reason was, instead of any mortar left on bricks being easy to wipe off like on common, my bricks have a serrated grooving pattern, so it was hard, and I tried various small brushes to help.
It is currently Wed Feb 05, 2025 6:06 pm
