Disconnecting the Red Hose From a Washing Machine From the Valve
lindylou30
by lindylou30 » Thu Aug 22, 2013 6:41 pm
I am trying to disconnect a washing machine and have found a problem with disconnecting the red hose from the valve which has a red plastic lever. I cannot turn the valve lever to shut it off because it is too close to the pipe. Can anyone help me please?
keeflester
Re: Disconnecting the Red Hose From a Washing Machine From the Valve
by keeflester » Sun Oct 20, 2013 2:50 pm
Take half a turn on the union connecting to the supply and rotate the valve until you can turn it off. Make sure to retighten the union once you are done. There should be little or no mess from leakage. I have done this on occasion and it has worked for me. Hope this helps
DIYorNot
by DIYorNot » Sat Nov 02, 2013 6:15 pm
lindylou30 wrote:I cannot turn the valve lever to shut it off because it is too close to the pipe.
Which pipe are you referring to - the washing machine flexible pipe or the cold water copper pipe?
It is currently Fri Jan 10, 2025 12:00 am
