Lighting in a Conservatory - Can I Fit a Dimmer Switch?
Tmw
by Tmw » Sun Sep 01, 2013 4:19 pm
Dimmer Switch Please help. I have a light fitting in the conservatory that is fed from the 13 amp circuit that is in the conservatory. The wiring comes from a fused socket and goes to a 5 amp fused switch. Finally the question, can I interrupt the wiring from fused switch to the light fitting with a dimmer switch.
Re: Lighting in a Conservatory - Can I Fit a Dimmer Switch?
by ericmark » Tue Sep 03, 2013 11:11 am
Using the grid switch system, dimmer, switch and fuse can all be in the same switch box.
Tmw
by Tmw » Tue Sep 03, 2013 7:04 pm
Thnk you Eric I will give it a go.
It is currently Wed Jan 15, 2025 5:47 am
