Heating Noise When Switching Heating System on
richardsonian49
by richardsonian49 » Thu Sep 12, 2013 11:40 am
I am concerned about a noise I hear in my house after the heating has been on.
It sounds like a clap of thunder and the whole house shakes.
Should I be really concerned?
Any advice greatly appreciated.
proptech
Re: Heating Noise When Switching Heating System on
by proptech » Thu Sep 12, 2013 10:17 pm
Yes, you should be concerned, but you haven't provided any information on your system.
A noise of the sort you describe cannot be ignored, and there could be a safety issue here.
So please do not switch on again until the problem can be sorted.
richardsonian49
by richardsonian49 » Tue Sep 17, 2013 12:28 pm
It is oil fired boiler 90/120 Bluebird.
5 bedroomed house with 16 radiators and a heated towel rail.
2 bedroom extension with ensuite bathrooms completed 2007.
richardsonian49
by richardsonian49 » Tue Feb 18, 2014 11:09 am
Hi All,
Got the boiler serviced by engineer.
Found out that the baffleshad burnt away due to too high a heat setting when the boiler was installed.
I had it checked and serviced before but obviously it was not done properly.
Got new baffles and installed them myself and problem solved.
It is currently Mon Nov 25, 2024 10:45 pm
