Covering Textured Wall Surface - How To Smooth It Over
Gruntfuttock
by Gruntfuttock » Mon Sep 30, 2013 11:26 am
I want to smooth over the textured walls in a room. The texture is very pointed and sharp. What's the best method to use bearing in mind I'm not a plasterer. Thanks
Re: Covering Textured Wall Surface - How To Smooth It Over
by welsh brickie » Tue Oct 01, 2013 9:46 pm
if its as bad as you say its easier to hack it all off and dryline the wall, giving you a smooth flat finish
Gruntfuttock
by Gruntfuttock » Sat Oct 05, 2013 8:26 am
Thanks Mr Brickie.
thedoctor
by thedoctor » Mon Oct 07, 2013 12:06 pm
Our projects section explains how to plaster over artex and other textured surfaces https://www.diydoctor.org.uk/projects/artex.htm there is also a great product for removing artex mentioned at the top of the page
It is currently Sat Nov 23, 2024 8:43 pm
