by proptech »
Thu Oct 03, 2013 10:52 pm
If you are saying that water is leaking through the heater itself, rather than a joint, I would suggest this is a defect in the heater's thermostat housing. The heater will have to be replaced.
The water pressure is only the distance to the tank above, and cannot be changed, nor can it be too high.
I have to ask why the cylinder was changed to an indirect when the coil is obviously not connected to anything.
For a solar system, you would need a special cylinder, this would be installed with the controls by the specialist installers.
