How To Remove And Replace A Door Handle
swayzak
by swayzak » Sun Oct 06, 2013 8:50 am
Sorry for basic question, but how do I remove & replace this door handle ?
http://imageshack.us/a/img593/5676/5pme.jpg
keeflester
Re: How To Remove And Replace A Door Handle
by keeflester » Sun Oct 20, 2013 9:37 pm
If there is no grub screw in the narrow waisted part of the handle, it is all one unit and can be removed by taking out the screws around the edge of the flange. They look to be somewhat damaged by previous work so I would advise you to replace the screws as a matter of course
themoffster
by themoffster » Thu Dec 05, 2013 10:08 pm
That will just be a single square metal rod running through the door from side to side.
One side will be in the round handle on one side and the same on the other.
Just unscrew the 4 screws on the round handle then pull the handle back off - you'll see a square metal rod. Rinse and repeat for the other side, then you can just get any other bog standard handle and stick it on each side. The square metal bar will be a standard size.
swayzak
by swayzak » Fri Dec 06, 2013 11:31 am
Thanks all
Sorted it - marginally more complicated than changing a light bulb once I got into it :)
keeflester
by keeflester » Fri Dec 06, 2013 5:10 pm
Congratulations and that should be a boost to your confidence.
It is currently Fri Oct 04, 2024 8:54 pm
