What To Use To Fill Gap Around French Doors
Kate239
by Kate239 » Wed Oct 09, 2013 8:33 pm
After having new French doors installed there is a gap which has been left which is approx 12inches long, 2 inches wide and 2 inches deep. After asking the installer to come back and fix it several times I have decided to do it myself. Can you please advise me the best filler to use.
Re: What To Use To Fill Gap Around French Doors
by welsh brickie » Wed Oct 09, 2013 10:04 pm
if there is a gap between the frame and the wall, then use expanding foam, leave it to set and then cut the excess off.
You can cover the gap later with a plastic trim, that you can buy from your local plastic suppliers
It is currently Mon Dec 23, 2024 8:47 am
