Shower Screen Seal Repair - What Can Be Used?
lostgeordie
by lostgeordie » Wed Oct 09, 2013 10:23 pm
The shower screen over the bath is failing. The hinge and wall fitting are fine, but the glass has started to come away from the hinge mech. This is basically a metal channel that the glass fits into. It looks like it was sealed in but the seal has failed and the glass has started to pull away
Can this be repaired, is a 'special' sealant or would a good quality silicone seal do the job ?
keeflester
Re: Shower Screen Seal Repair - What Can Be Used?
by keeflester » Sun Oct 20, 2013 7:31 pm
Go to your local buildbase and ask for CT1 sealant. It comes in a range of colours, works in the wet and is a hundred times better than silicone. It is a very effective high grab adhesive as well as a sealant and really does work for pretty much everything.
lostgeordie
by lostgeordie » Wed Oct 23, 2013 6:03 pm
Keeflester, thanks for that and I'll give the CT1 a go
It is currently Mon Jan 27, 2025 2:21 pm
