New Door Tubular latch 2.5 Or 3 Inch?
chriscba
by chriscba » Thu Oct 10, 2013 9:25 pm
I'm fitting a new door, do I use a 2.5" or 3" tubular latch
proptech
Re: New Door Tubular latch 2.5 Or 3 Inch?
by proptech » Fri Oct 11, 2013 1:01 pm
It all depends on what door furniture you are fitting. the shorter latches are fine with lever handles, but you will catch your knuckles if knobs are used. You can get even longer versions, Union make some with a 91mm body, giving a 71mm backset.
It is currently Sat Sep 28, 2024 12:39 pm
