knocking Out A Bricked Up Door To Divide 2 Rooms
greyhoundlady
by greyhoundlady » Fri Oct 11, 2013 6:25 pm
I need to put a door back into the hall so I can divide our through lounge back into two rooms as I need to use one as a bedroom. I have started to remove the plaster in the hall there is a hairline crack in the plaster so I had a good idea where to look and have found the plaster is a very fine skim with what appears to be a inch of cement under it,it is very hard and I am struggling to knock it off, the brick work is built with the same mix. I have never done this before I am presuming that if the door way was here before they will just have removed the frame and bricked it up, so I can just knock it out and install a door liner? I my plan is to continue to chip the plaster off then drill through the morter till I can knock the bricks free. The house was built about 1935 and this was probably done in the 1970's it is a mid terrace and there is a wall upstairs above this one but I am not sure if they are connected as I know some of the walls upstairs are built on top of the floorboards. I am a carer and a single mum and cannot employ a builder as money is very tight and I already am having to use this room as a bedroom but I am quite able for a unskilled mum I just need to know how to do things My son will help he is autistic and had done carpentry level 2 so I am hoping we can do the carpentry bit if he thinks about it. I am just unsure if there should be a lintle and if there should how to install one. I have watched my dad put one in in the past but have never done one myself. Thanks for your help
Re: knocking Out A Bricked Up Door To Divide 2 Rooms
by welsh brickie » Fri Oct 11, 2013 9:31 pm
don't start knocking any bricks out without inspecting the lintol, if there is one. Take the plaster off first where the lintol is supposed to be.
It is currently Fri Jan 10, 2025 9:34 am
