Toilet Drain And Gaps In Flooring Around The Waste Pipe
Amyea
by Amyea » Sun Oct 20, 2013 8:01 pm
In my bathroom there is a space in the floor behind the toilet where the drainage system goes but it's not tight to the floor, the hole where the drain goes is big so I get a lot of insects coming up through the hole. Can I block the hole with expanding foam or something? Will this damage the drainage pipe or is it just simply that whomever installed the toilet made too big a hole in the floor?
proptech
Re: Toilet Drain And Gaps In Flooring Around The Waste Pipe
by proptech » Sun Oct 20, 2013 10:14 pm
Any chance of a photo ? Not easy to answer you without knowing a bit more of the problem.
It is currently Sat Jan 11, 2025 7:46 pm
