AEG Built In Fridge Freezer Leaking
altrev47
by altrev47 » Tue Oct 22, 2013 10:05 pm
Aeg santo n 9 18 42-4i 4i. Built in Fridge freezer
We have noticed water gathering on the edge of the fitted unit below the freezer section, not in the FF itself. There is no water under the FF just on the lip of the fitted unit below. Could water be coming from bottom of door seal ? Although there's no water on bottom shelf of freezer. There's no water coming from below freezer beyond the edge underneath. Can't see where water could be coming from.
Any pointers would be appreciated.
keeflester
Re: AEG Built In Fridge Freezer Leaking
by keeflester » Wed Oct 23, 2013 7:01 pm
It's quite possibly the result of condensation of moisture on the cold underneath surface. Kitchens are warm moist places and that moisture all has to go somewhere. It will condense on the coldest surface in the room.
TheDoctor4
by TheDoctor4 » Fri Jul 18, 2014 1:26 pm
Just a note to say, if any future readers need info on moving or transporting fridges or freezers we now have some project information on doing so:
https://www.diydoctor.org.uk/projects/mo ... reezer.htm
It is currently Thu Nov 21, 2024 7:06 pm
