Old Central Heating System Mystery Part That Needs Replacing
diy_monkey
by diy_monkey » Fri Nov 15, 2013 8:35 pm
Hi All,
I have a mystery part that has sprung a leak! It's attached to the central heating system near the boiler. The system is very old with a back boiler in the lounge.
Cheers, Alex
http://www.flickr.com/photos/too_obscura/10874414316/
http://www.flickr.com/photos/too_obscura/10874380215/
proptech
Re: Old Central Heating System Mystery Part That Needs Replacing
by proptech » Sat Nov 16, 2013 8:30 pm
The part in your photos is an old safety valve. these are no longer used, and can be removed. I can't be sure from the photo, but I suspect it's 3/4 so could be replaced with a 3/4 BSP brass plug.
diy_monkey
by diy_monkey » Mon Nov 18, 2013 7:03 am
Thanks proptech, I've managed to swap it for the part you mentioned and no more leaking. Only cost£1.98!
It is currently Sat Jan 25, 2025 2:11 am
