Wiring an Xpelair C100HT Humidistat Extractor Fan Directly
SSdF
by SSdF » Sat Nov 23, 2013 11:24 am
Dear All,
We are planing to install an Xpelair C100HT Humidistat extractor fan in the bathroom and wanted to connect it directly rather than using switched live from the lighting circuit. But we are planning to take feeds (L and N) from the lighting circuit (ceiling rose). The reason is we need to use the shower/bathroom during the day times and do not need to have lights on. Xpelair's proposed installation is also similar to this. I have attached it below. We are not going to add the optional lamp in the circuit, but planning to use a FCU (DP) with a 3A fuse as the fan isolator.
We are very grateful for your views and advise on this.
Thanks, SSDF
Diagram
Diagram
collectors
Re: Wiring an Xpelair C100HT Humidistat Extractor Fan Directly
by collectors » Mon Jul 28, 2014 10:53 am
You will still need some way to switch the fan off to isolate it.
You could buy one with a pull switch if its going in a wall or fit a second switch just for the fan using a pull switch or an external wall switch.
It is currently Fri Nov 29, 2024 9:40 pm
