Infra Red Lamp With 250 Watts Rating - Some Advice Needed
Hatshepsutt
by Hatshepsutt » Wed Dec 04, 2013 4:41 pm
I bought this bulb/lamp to use as a method of resting meat and poultry (after cooking) so that it does not get cold. I cannot find a light fitting that is rated at 250 watts.
What will be the consequences of screwing it into a holder rated at (say) 80W?
Are there any other issues that I should consider in setting it up and using it?
keeflester
Re: Infra Red Lamp With 250 Watts Rating - Some Advice Needed
by keeflester » Fri Dec 06, 2013 1:18 pm
The worst that can happen is a fire, you should go to the supplier of the lamp and task them with suggesting a suitable socket. You must not use this lamp in an ordinary domestic light fitting.
by ericmark » Sat Dec 07, 2013 1:52 am
Google "porcelain lamp holder" I found loads rated 16A
It is currently Thu Nov 21, 2024 6:57 pm
