Pumped Feed to Hot Water Tank and Diameter of Pipework
billy-b
by billy-b » Fri Dec 06, 2013 11:39 am
I am in the process of fitting radiators and pipework ready to have a boiler fitted. I have a gravity fed hot water tank which has a solar panel heating with an immersion heater for top ups in the winter and it also has two auxiliary heating coils, I wish to feed one of these coils from the boiler instead of using the immersion heater. Whilst I accept that 22mm pipes are required if heating the tank by gravity, is it ok to use 15mm from the boiler pump. The tank is probably about 5 metres from the boiler
proptech
Re: Pumped Feed to Hot Water Tank and Diameter of Pipework
by proptech » Fri Dec 06, 2013 8:10 pm
Hi billy-b
22mm should be used for this, remember to include a balance valve on the return. For a gravity system 28mm would be used.
It is currently Fri Jan 10, 2025 1:17 am
