Loud whooshing noise when hot water tap is turned on .
Iceman99
by Iceman99 » Wed Jan 01, 2014 8:17 pm
We have a loud whooshing noise when the hot water tap is turned on downstairs and up stairs , it's not coming from the boiler , but from above the kitchen , it's been getting worse , had a plumber round and he thinks it is an isolation valve not fully opened in the ceiling somewhere ? Had a major refurb on the house over a year ago no issues then , but did have a leak on my mains line outside recently could some grit get into the system ? Can it be anything else ? We are in a hard water area could it be build up in the pipes ? Can it be cleaned ? Any ideas would be great .
thedoctor
Re: Loud whooshing noise when hot water tap is turned on .
by thedoctor » Mon May 19, 2014 3:23 pm
Do the hot taps splutter when opened or is the flow uniform and constant?
It is currently Thu Jan 09, 2025 3:15 pm
