Using Lightweight Blocks for Inner and Outer Walls of Garage?
DOWAX002
by DOWAX002 » Thu Jan 02, 2014 10:57 pm
can i use lightweight blocks for both inner and outer walls on a garage bulid?
Re: Using Lightweight Blocks for Inner and Outer Walls of Garage?
by welsh brickie » Sun Jan 05, 2014 11:50 pm
you don't need to build a cavity wall for a garage, but if you want to, it would be stronger to build the outer skin in solid or hollow concrete block and use the lightweight blocks for the internal skin
It is currently Fri Nov 15, 2024 7:34 am
