Leak From Behind Panels - How to Seal From Behind?
rosterry
by rosterry » Wed Feb 05, 2014 3:08 pm
I have a corner shower which is lined with plastic panels - the honeycomb type panels are about 12" wide- when they were installed the plumber sealed the joints from behind, but now they are leaking.
How can I re-seal them is there a spray or something I can put in the joins
Re: Leak From Behind Panels - How to Seal From Behind?
by stoneyboy » Sat Feb 15, 2014 11:20 pm
rosterry,
You apply a bead of silicone sanitary mastic down each join. The problem will be getting the joins dry enough for the silicone to adhere. This is a job for the dryer weather when you can leave a window open and not use the shower for a few days. Check for dryness by holding a tissue in the lowest part of the joins.
It is currently Sat Jan 11, 2025 8:48 pm
