Repairing Damp Plaster - What to Fill Patches With?
Ronan82
by Ronan82 » Fri Feb 07, 2014 6:47 pm
Dear all,
I've recently removed the lining paper in my living room due to damp patches forming caused by the adjacent building.
I've sorted the source of the damp but I have found that there are some large areas of damaged plaster.
The plaster is very old horse hair plaster and I intend to chip off the damaged plaster back to the lath and then re patch the damaged areas.
My question is....what should I fill the damaged areas with?
ShouldI I use a plaster repair formula e.g. Pollyfilla plaster repair or should I just go right in and should I use a multi finish plaster mix.
I'm not overly confident with plaster so any advice would be more than welcome.
Many thanks!
Re: Repairing Damp Plaster - What to Fill Patches With?
by welsh brickie » Fri Feb 07, 2014 10:19 pm
use carlite bonding, it will set in about 2 to 3 hours, once set you need to scrape it back 3mm from the finished surface to allow the finishing plaster, use thistle multi finish plaster for the final coat
Ronan82
by Ronan82 » Fri Feb 07, 2014 10:35 pm
Thank you very much!
It is currently Sat Nov 23, 2024 9:50 pm
