Grant 16 Inch Back Boiler With Oil Heating Link Up
ashleyclfc
by ashleyclfc » Mon Feb 17, 2014 9:22 pm
hi guys need help have a grant back boiler open fire which i use everyday has a pump installed near fire which i have to switch on everytime i light fire due to link up
i am getting good hot radiators but my hot water cylinder never gets hot enough for a bath even if i have fire light all day 8 hours + its getting annoying as my mum has same set up n has hot rads and hot water right threw until next day
the hot water cyclinder was replaced but 6 months ago due to the other leaking but i have never had roasting hot water from fire any info or help would be greatly appreciated
many thanks
DIYDoctor2
Re: Grant 16 Inch Back Boiler With Oil Heating Link Up
by DIYDoctor2 » Mon May 19, 2014 1:54 pm
Do you have a thermostat on your cylinder, and if so is it turned right down?
Otherwise it could be a zone valve or an air lock.
Did you mention the problem you were having to the heating engineer who changed your tank 6 months ago? If so call him back and tell him it is no better.
or find a reliable qualified heating engineer in your area on our Find a Tradesman section https://www.diydoctor.org.uk/find-tradesmen/
For a guide to heating systems and how they work visit our Projects section
https://www.diydoctor.org.uk/projects/domestic_hot_water_systems.htm
It is currently Thu Jan 09, 2025 3:19 pm
