100mm Holesaw - Need to Locate Arbour to Fit Drill or Holesaw
carbar
by carbar » Mon Mar 03, 2014 8:53 am
Hello
I need to drill a 100mm diameter hole in my ceilng. I have a set of holesaws, but they are too small, so I bought at 102mm holesaw.
Unfortunately it didn't fit the arbour that came with my set, as the holesaw has a circular hole but the arbour has a partially round shaft with two straight edges.
So I bought an new arbour with a circular shaft, but it was too large to fit into my drill.
So, my question is - can I get a 102mm holesaw that will fit my existing arbour, or alternatively can I get an arbour with a circular shaft that will fit my drill?
Thanks,
Carl
proptech
Re: 100mm Holesaw - Need to Locate Arbour to Fit Drill or Holesaw
by proptech » Mon Mar 03, 2014 6:35 pm
Hi Carl
The normal size of an arbor for that size holesaw will fit a 1/2 inch chuck, In most cases the saw would screw onto the arbor, and be secured by two pins. The shank being 1/2 inch hexagon, although there are 5/8 versions.So the question is, what size is your drill chuck, and what size is the arbor ?
I do have to say that if your drill is a cordless version, I doubt that it would have the power to cope with a 102mm holesaw, You need a lot of torque, even in plasterboard.
It is currently Sat Nov 23, 2024 2:07 am
