Felt Nails With Extra Large Heads - Where Can I Get Them?
6 posts   •   Page 1 of 1
fishnet
by fishnet » Wed Mar 05, 2014 8:48 pm
I am replacing the felt on my shed. The felt nails I am removing have heads which are larger than any replacements I have found. Can anyone advise where nails with extra large heads might be available - or are these no longer in production
The length would ideally be around 18 mm
proptech
Re: Felt Nails With Extra Large Heads - Where Can I Get Them?
by proptech » Thu Mar 06, 2014 9:18 am
Hi fishnet
Try Screwfix - catalogue number 14831 for 13mm (usually long enough) or 17718 for 20mm.
by welsh brickie » Thu Mar 06, 2014 4:34 pm
fishnet
by fishnet » Tue Mar 11, 2014 8:31 pm
sorry - I should have made it clearer - I have already tried both screwfix and tool station and the heads in both 13 and 20 mm length are much smaller than the old felt nails I am removing
perhaps this a case of ''they don't make them like they used to''
does anyone know where I might lay on my hands on some old stock
Thanks for trying Fishnet
proptech
by proptech » Wed Mar 12, 2014 7:26 pm
You said it "they don't make them like they used to" Those from the likes of Screwfix are perfectly OK for the job though.
I think you'd have to go back a lot of years to see the ones you think are better.
Why do you want bigger heads ? With a shed I would always use a polyester based felt, it won't tear like the old stuff, and certainly can be fixed with today's nails.
fishnet
by fishnet » Thu Mar 13, 2014 6:35 am
Thanks for the advice proptech - will give it a try - regards fishnet
It is currently Thu Oct 31, 2024 6:12 pm
