On Suite - Need to Take Hot Water Feed From Boiler
Lesthemat
by Lesthemat » Mon Mar 10, 2014 9:34 am
Hi, please can someone tell me if and how I can take a hot water feed from my combi boiler which is located next door. Many thanks Les
proptech
Re: On Suite - Need to Take Hot Water Feed From Boiler
by proptech » Mon Mar 10, 2014 6:32 pm
Hi Les
You haven't provided a lot of info, but I assume you wish to provide a supply for an additional hot tap. On a combi boiler there is only one hot water outlet that is tee'd off to the various taps. Therefore just locate the correct supply, and insert a tee. If there is any doubt as to your capability to do this, get a registered installer to carry out this work.
It is currently Sat Jan 11, 2025 7:59 pm
