by proptech »
Mon Mar 24, 2014 10:03 am
Hi sonia1309
I know the ones you mean. That little screw needs to be quite tight, and the screwdriver needs to be a very good fit in the screw. In your case it could be that the back plate is distorted. It may help if the plate is removed from the wall, and turned up the other way.
Failing that, it is possible to obtain something a lot better, but you will have to shop round a bit.
