Corner Panel Split and Opening on Conservatory
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
brendon1703
by brendon1703 » Mon Mar 24, 2014 8:33 pm
We had our conservatory put up in 2008 and in the last year there has been a slightly gap appearing on the corner which is slowly getting bigger. The gap is on the lower corner panel which joins the side panel, the gap at the bottom is about 5mm. It looks like the side panel is coming away from the front panel.
I have tried pushing closed with no luck, but worried the gap will get bigger.
Many thanks
Brendon
Re: Corner Panel Split and Opening on Conservatory
by welsh brickie » Tue Mar 25, 2014 7:24 am
you can remove the plastic beads with a sharp flat paint scraper, then remove the panel and reposition, silicone in place then refit the beads
It is currently Sun Dec 22, 2024 8:36 am
