by thedoctor »
Thu Aug 02, 2007 11:53 pm
$ sharp sand or flooring grit (pretty much the same thing) to 1 cement. Mix with a little water until you can squeeze a lump in your hand so that it stays in one lump but no water runs out. No need to do anything to concrete base except make sure its free from dust and loose stones etc and wet down before you lay the screed. The whole floor should be damp as you lay.
