Quick response asap please - Relief valve leak
StongBrew
by StongBrew » Fri Apr 11, 2014 8:05 pm
Hi. Need a quick bit of help, nothing like a bit of Friday night plumbing.
Noticed boiler had lost pressure so gone to top it up and noticed a leak from above pic, guessing its a pressure relief valve? The black cap on top is slightly loose, done it up and it does stop the leak but should this be done up tight or is that a stupid question.
Regards
StongBrew
Re: Quick response asap please - Relief valve leak
by StongBrew » Sat Apr 12, 2014 4:53 pm
Attached pics now of leak:
proptech
by proptech » Sat Apr 12, 2014 6:12 pm
Hi StrongBrew
That is an automatic air vent. Tightening will stop the leak, but, you will have to replace it. In normal use the cap is left loose to allow the air to escape, water is contained by a float valve.
It is currently Thu Jan 09, 2025 12:43 pm
