Sofa foam filling - what is this filling called?
mick.n
by mick.n » Sun May 04, 2014 3:37 pm
We had our 6 year old sofa taken away by a local tradesman last year to put new filling in as it was sagging badly. It has been ok untill recently, but the cushion that gets used most has started sagging again.
Being curious, i took the bottom fabric off to have a look to see what the repair man had done & i found he had used 3 slabs of this type of foam under each cushion.
As you can see from the pics, it is a multi coloured mixture of all kinds of foam. Anyone knows what the correct name is for this filling so i can try to track some down? It's about 1" thick.
thedoctor
Re: Sofa foam filling - what is this filling called?
by thedoctor » Mon May 19, 2014 11:25 am
Hi, not really our field I'm afraid but Ive had a look round for you and the closest I can get in the high density foam category is this.
It comes in varying thicknesses and can be bought here
https://www.anyfoam.co.uk/sheet-foam.php
It is currently Tue Nov 26, 2024 12:22 am
