Change of Use From Garages to House Dwelling - Planning Approval Opinions
vkharch
by vkharch » Mon May 19, 2014 3:59 pm
I am looking at the possibility of demolishing a set of mainly detached garages (partly detached to other garages at the higher level and partly to retaining wall, it is a sloping area) and build a house dwelling. Garages are located in Bromley, London.
I'd be interested in others experience/view regarding getting planning approval to build 1-2 storey house on the whole plot about 15m x 5m, which is freehold though access to the plot is via driveway on a lease. I've contacted planning department however they said that they would not be able to advise until they get an application.
Thanks in advance.
Re: Change of Use From Garages to House Dwelling - Planning Approval Opinions
by welsh brickie » Mon May 19, 2014 9:13 pm
you need an architect to draw an outline planning approval request, for what you require, The planning officer will then approve or deny the plans based on the plan proposal, you may need to alter a few details to pass the design, this will be discussed with meetings with the council
vkharch
by vkharch » Tue May 20, 2014 12:30 am
welsh brickie wrote:you need an architect to draw an outline planning approval request, for what you require, The planning officer will then approve or deny the plans based on the plan proposal, you may need to alter a few details to pass the design, this will be discussed with meetings with the council
Thanks for reply welsh brickie, would I be able to use the whole area where the garages are at the moment or there should be some limitation to the house rebuild area?
by welsh brickie » Tue May 20, 2014 2:07 pm
Im afraid only the planning officer can answer that.
