New Radiator Fitted and Now no Hot Water?
Colwood63
by Colwood63 » Thu May 22, 2014 10:29 pm
Hello
I am new here and have just bought my first house. Have been doing renos and last night had a new radiator fitted by a plumber. All seemed to be fine except today I have no hot water. Also the overflow pipe is now dripping. Finally, the multihead G pump is now really noisy when the hot water is turned on. None of these problems existed prior to yesterday so they must be related to the rad being fitted right?
Can anyone advise? I would like to fix myself if possible without getting plumber out again.
Thank you!
proptech
Re: New Radiator Fitted and Now no Hot Water?
by proptech » Fri May 23, 2014 12:00 pm
Hi Colwood63
It sounds like there is still air in the system after being drained. Your plumber should have made sure that all was working correctly before leaving.
In order to advise for a DIY remedy we would need a lot of info on the system. The best course of action would be to get the plumber back, and don't try to use the system in the meantime, if the pump is running dry, it could be damaged.
It is currently Thu Jan 09, 2025 11:56 am
