laminate flooring
LIZB994
laminate flooring
by LIZB994 » Fri Aug 03, 2007 3:21 am
I have a few pieces of laminate flooring that I need to remove. The pieces are in the middle of the room. Ho I remove these few pieces and replace them with new ones.
by htg engineer » Thu Aug 09, 2007 5:02 pm
you can't, you'll have to take it up from one end of the room and then relay.
alex1982
How do i lay laminate flooring
by alex1982 » Fri Aug 17, 2007 11:30 pm
Im quite new to this give me some infomation please Thankyou
alex1982
Garland
by Garland » Tue Oct 23, 2007 8:30 pm
You need to buy a plank removal tool.
Obviously you won't be able to 'click' in a new plank. Instead you will have to cut off the tonuge and groove edges and glue the new plank in place. Hope this helps.
It is currently Fri Nov 22, 2024 6:13 pm
