Looking to replace a basin in bathroom - what fitting is this?
barkinglama
by barkinglama » Sat May 31, 2014 6:20 am
anyone tell me what this fitting is called and how it comes off and is it reusable?
http://imgur.com/1Hnn1LA
thanks
proptech
Re: Looking to replace a basin in bathroom - what fitting is this?
by proptech » Sat May 31, 2014 6:58 pm
Hi barkinglama
That's a Hep2o fitting. Two fittings together, a tap connector, and a coupler used to extend the pipe. It can be removed from the tap simply by loosening the hex nut. To remove the fitting from the pipe you need a HepKey, a little plastic tool that releases the grab ring in the fitting. These are available from a lot of plumbers merchants in all sizes for about 40 pence.
barkinglama
by barkinglama » Sun Jun 01, 2014 9:56 am
Ta Muchly
It is currently Tue Dec 24, 2024 4:47 pm
