How to Improve Support for Retained Chimney Stack?
Andybambi
by Andybambi » Tue Jun 03, 2014 11:24 am
Hello,
I've had a survey carried out on a house I'm buying and it states 'improved support required for retained chimney stack in roof space above middle bedroom'.
Can someone advise how this can be achieved?
Re: How to Improve Support for Retained Chimney Stack?
by welsh brickie » Sun Jun 08, 2014 3:10 pm
you will need to install a steel beam from one wall to another and fit smaller beams off that, into the gable brickwork to support the stack,Or fit what they call gallow brackets its really not a diy project and the beam needs to be calculated to support the weight, a structural engineer can do that for you.
philipam
by philipam » Thu Jun 12, 2014 10:53 pm
Failing that, just remove the rest of the chimney.
It is currently Sun Nov 24, 2024 9:03 pm
