Increasing the Strength of Ceiling Joists by Adding Timbers on Top?
Andybambi
by Andybambi » Wed Jun 04, 2014 1:17 pm
Hello,
I am in the process of buying a house and will be looking at converting the attic to a storage/playroom but think I will have to re-enforce the ceiling joist to handle the weight. I understand that this can be done by sistering the joists but was wondering if I could simply increase the depth of the joists? For example, if the joists are 2x5 could I not glue and bolt a 2x3 length of timber on top of it effectively transforming it into a 2x8.
Any advice you can provide will be greatly appreciated.
collectors
Re: Increasing the Strength of Ceiling Joists by Adding Timbers on Top?
by collectors » Fri Jun 06, 2014 4:07 pm
Not in any way that would be economical. You would end up having to run metal plates down either side of each joist & it would not be worth it. You should also make sure you get graded timber for this sort of work.
It is currently Mon Nov 25, 2024 1:56 am
