Brick Expansion Rate and Volume of 40 Meters of Brick Wall?
6 posts   •   Page 1 of 1
mrdwy
by mrdwy » Thu Jun 26, 2014 2:20 pm
I am going to demolish my garden wall, approx. 40 square metres .
My question is this,
How much volume will 40 metres of brick walling create once its been demolished. What size of skip will be needed ?
Re: Brick Expansion Rate and Volume of 40 Meters of Brick Wall?
by welsh brickie » Thu Jun 26, 2014 6:04 pm
size of block needed...to calculate
mrdwy
by mrdwy » Thu Jun 26, 2014 6:12 pm
welsh brickie wrote:size of block needed...to calculate
It's a single brick wall
by welsh brickie » Thu Jun 26, 2014 6:14 pm
4.5 tonnes
mrdwy
by mrdwy » Thu Jun 26, 2014 6:20 pm
So a 4 metre skip will be enough ? , I ask as tonage is not the same by volume as sand or ballast
philipam
by philipam » Thu Jun 26, 2014 10:51 pm
When you say 40m of brickwall do you mean 40m2??
If so you are looking at 2400 bricks these alone will weigh somewhere in the region of 6 tonnes + the mortar used to lay them in the region of an other 2 tonnes.
Now if you lay them in the skip with no voids you might get them all in a 8 yrd skip.
It is currently Sun Nov 24, 2024 8:29 pm
