double light switch
maja
double light switch
by maja » Fri Aug 03, 2007 4:34 pm
I have removed a double dimmer switch which worked six wall lights,four lights on one switch and two on the other. I need to replace it with a normal double switch. How do I wire it to work the same
BLAKEY1963
Re: double light switch
by BLAKEY1963 » Sat Aug 04, 2007 2:39 pm
[quote="maja"]I have removed a double dimmer switch which worked six wall lights,four lights on one switch and two on the other. I need to replace it with a normal double switch. How do I wire it to work the same[/quote]
MAJA
ON YOUR DIMMER BEFORE U DISCONNECT WIRES, START WITH ONE DIMMER FIRST. THE COMMON ( FEED ) GOES IN TO COMMON
OF THE FIRST OF TWO SWITCHES ON THE TWO GANG UNIT, AND
THE SWITCH WIRE ON DIMMER PROBALY MARKED LOAD GOES INTO
L2, OR 1 WAY DEPENDING HOW IT IS MARKED ON TWO GANG SWITCH.
THE OTHER DIMMER, WOULD BE NOW CONNECTED ONTO THE SECOND SWITCH OF THE TWO GANG UNIT. AGAIN COMMON OF DIMMER INTO
COMMON OF SWITCH , AND SWITCH WIRE INTO L2 OR ONE WAY.
BLAKEY1963
It is currently Mon Jan 13, 2025 2:13 am
