Drilling Wall Plate - Is This Permitted and if Where to Drill Hole?
aledlgriffith
by aledlgriffith » Mon Jun 30, 2014 11:11 pm
I need to drill a wall plate that supports joist hangers and joist in my extension. I need to do this so I can run 22mm pipes to connect the repositioned boiler to the existing pipework for my central heating system. Is it permitted to make a hole in the wall plate and if so where would I drill the hole in the plate. Thanks
thedoctor
Re: Drilling Wall Plate - Is This Permitted and if Where to Drill Hole?
by thedoctor » Tue Jul 01, 2014 5:13 pm
Hi, yes this is Ok. The best place to drill is mid-way between joists so that each joist stillhas the maximum bearing either side
It is currently Thu Jan 09, 2025 3:11 pm
