230v 3600 Watt Industrial Vacuum Cleaner - Can you Use This on Domestic Socket?
georgelucas
by georgelucas » Sat Jul 12, 2014 1:49 pm
hi
I got hold of numatic ntt 2034 vac - its 230v 3600w vac with as I believe a plug that has been replaced from industrial to domestic one.
is it safe and any wise to try this vac on domestic socket?
thank you for help.
Re: 230v 3600 Watt Industrial Vacuum Cleaner - Can you Use This on Domestic Socket?
by ericmark » Sat Jul 12, 2014 11:24 pm
These units often have three have three motors 1.2kW each used to suck up water etc. before concrete pours. Likely you can disconnect one motor and blank it off and run with just two motors.
With these industrial units one has to understand they do not work on vacuum but air volatility. Having the correct gap between the pick-up and floor is very important. I have worked on some very large units around 60 horse power for cleaning streets and getting the gap right is an art. Set correct it could suck up bricks.
It is currently Tue Jan 14, 2025 12:47 pm
