Leaking Asbestos Garage Roof - How to Better Seal up Leaks?
mandyspangles
by mandyspangles » Thu Jul 17, 2014 2:53 pm
Hello
I'm hoping someone can offer advice with regard to my leaking roof. My garage is, i believe, a 1980s kit one with a corrugated asbestos roof. Over the years it has become very porous. I have tried the usual bitumen at joints and then an expensive paint-on preparation which failed within weeks. I am currently looking at encapsulation on a website called asbestosafe. It's hugely expensive so I'm wondering if I have any alternatives. DIY is impossible for me. Many thanks.
Re: Leaking Asbestos Garage Roof - How to Better Seal up Leaks?
by welsh brickie » Thu Jul 17, 2014 10:41 pm
you could try isoflex rubber compound
mandyspangles
by mandyspangles » Fri Jul 18, 2014 2:24 pm
Thank you for your reply.
How would this be applied?
RubberRoofer
by RubberRoofer » Wed Jan 07, 2015 4:30 pm
I don't know where you are - but we use Asbesosil. It's a liquid applied silicone based membrane that cures to a seamless encapsulation membrane and waterproofs all in one.
However it's not cheap at all. Anything good for Asbestos isn't - I've yet to find a cheap solution to this problem that works - when I do I'll be using it.
What size is the garage, and how much are you being charged?
Work on around £60-£80 per M2 but do check that they are either Trading Standards "Buy with Confidence" Members or "Which? Trusted Traders" - then you will know what you're getting will be a quality service and product - too many cowboys out there, although I haven't heard of the company mentioned specifically.
It is currently Sat Nov 23, 2024 1:23 am
